How update custom field(insight) with automation rule ?
Alex
January 25, 2024 edited
Hi, everyone ! Tell me please what needed add in automation rule , that it copy field from parent issue to in linked issue? My problem is that this this is the same field ("insight" Сfield).
i try madу it , but it not work for me:
In log i get error :
Field customfield_21501 cannot appear in both 'fields' and 'update'
Thank you any help!
Regards Alex!
Florian Bonniec
Hi @Alex
In your case the error is due to the fact that you selected your field in the list the fields but you also update it from the additional field section.
Regards
Alex
January 25, 2024
@Florian Bonniec hi!
Please tell me if this can be implemented in some other way?
Register today
