  • Community
  • Q&A
  • Jira
  • Questions
  • I am getting error, JIRA Startup failed - The following plugins are required by JIRA, but have not been started:
ooshmi sahoo
June 13, 2013
  • Embedded Gadgets Plugin (com.atlassian.gadgets.embedded)
  • Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard)
  • Gadget Directory Plugin (com.atlassian.gadgets.directory)
  • Atlassian JIRA - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
  • Please help. I have stopped service and then also tried as error. How do i access jira locally?
AlaA
June 13, 2013
Hello Ooshmi,
I think that the problem you are having here is related to the plugins being timedout. Can you try to add the following line to your startup arguements:
-Datlassian.plugins.enable.wait=300
And then restart your JIRA instance to check whether that solves the problem or not?
MikeH
October 2, 2013
For Linux add the following line after EXECUTABLE= in the startup.sh file:
export JAVA_OPTS="$JAVA_OPTS -Datlassian.plugins.enable.wait=300"
A
June 19, 2013
oosmi
does the server have any firewall or anti virus blocking JIRA. disable it for some tile to validate this point.
this Kb might be of helphttp://confluence.atlassian.com/display/JIRAKB/JIRA+Fails+to+Start+Due+to+Bundled+Plugin+is+Disabled
ooshmi sahoo
June 19, 2013
I am using trial version of jira. First time when I used this getting etror.
Harry Chan
June 19, 2013
What specs are the server? Maybe it's too slow to run it causing the timeouts?
Johannes Kilian
June 13, 2013
Are you using a test version of JIRA? This error occured at my test machine after expiration of JIRA test license ...
KieranA
June 13, 2013
Hi ooshmi,
This doesn't sound like a SourceTree issue to me, could you edit your tags to reflect JIRA instead?
