I am not able to create a ticket
Venkata Sagar July 19, 2022
Hi Team,
I have an Script, I have kept it in Post function. The Scenario is when we select the Label "PDE_Support " the Due date should be auto populate based on the Priority.
The Script is working fine , checked it on the Previous Tickets. The Problem here is like when i select the PDE_Support Label. the Issues are not creating getting error like
We can't create this issue for you right now, it could be due to unsupported content you've entered into one or more of the issue fields. If this situation persists, contact your administrator as they'll be able to access more specific information in the log file.
Script:
/*import com.atlassian.jira.issue.label.Label;
import com.atlassian.jira.issue.IssueManager
import java.sql.Timestamp;
import com.atlassian.jira.issue.customfields.manager.OptionsManager
import com.atlassian.jira.issue.customfields.option.Option
import groovy.time.*
import com.atlassian.crowd.embedded.api.User
import com.atlassian.jira.config.PriorityManager
import org.slf4j.Logger
import org.slf4j.LoggerFactory
import com.atlassian.sal.api.user.UserManager
import static com.atlassian.jira.issue.IssueFieldConstants.PRIORITY
def constantsManager = ComponentAccessor.getConstantsManager()
def userUtil = ComponentAccessor.getUserUtil()
log.debug ComponentAccessor.getComponent(UserManager)
def priority = issue.getPriority()
def pname=priority.name.toString()
def issueManager = ComponentAccessor.getIssueManager()
Issue issue = issue
def duedate = customFieldManager.getCustomFieldObject("customfield_47440")
Calendar cal = Calendar.getInstance();
def temp = cal.getTimeInMillis();
def add = 0;
def x = 1000*24*60*60L
def mydueDate = new Timestamp(cal.getTimeInMillis());
Set<Label> labels = issue.getLabels()
if (labels.find { it.getLabel() == "PDE_Support"}) {
if (pname == "0")
add = 1*x
temp = temp+add
mydueDate.setTime(temp)
issue.setCustomFieldValue(duedate, mydueDate)
def currentUserObj = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
issueManager.updateIssue(currentUserObj, issue, EventDispatchOption.DO_NOT_DISPATCH, false)
else if (pname == "1")
add = 14*x
temp = temp+add
else if (pname == "2")
add = 28*x
temp = temp+add
issue.setCustomFieldValue(TargetCompletionDate, mydueDate)
}else if(pname == "3")
add = 90*x
temp = temp+add
else if(pname == "4")
add = 180*x
temp = temp+add
Fabio Racobaldo _Catworkx_
Hi @Venkata Sagar ,
that error should be related to object type that is not consistent with the custom field type.
DateTime custom field supports Timestamp object type. Try to define mydueDate as Timestamp and not as def.
Timestamp mydueDate = new Timestamp(cal.getTimeInMillis());
Fabio
