I am trying to implement this workflow into JIRA
Caleb Park
Hi guys,
I am trying to implement my workflow into JIRA.
The following is the workflow:
Is there a good way to incorporate this into JIRA?
Any suggestions or ideas?
Matt Parks
April 8, 2024
I don't know enough about what is happening during each 'Do this task' section to know exactly how to set it up.
My first thought is that each rectangle in the workflow is a separate status and the decision points in between as to whether the change should go forward are two separate transitions.
For example, after the issue is created it stays in the initial status until a decision is made to either transition into the 'Do this task' status or to the Archive status.
What conditions/validators/post-functions you execute on these transitions is up to you, and partially dependent on what plugins, if any, you have installed in your instance.
Register now
