I am unable to search using custom field.
Jagjeet Randhawa
December 28, 2015
Here is the API I am using
https://company.atlassian.net/rest/api/2/search?jql=project=UWS&customfield_10803=abcd&maxResults=2&fields='assignee,status,resolution'
The API returns the latest tickets for that project not taking into account the value of the custom field value specified in the API.
joachimbollen
December 28, 2015
You'll need to make a correct JQL statement to include the custom field like
https://company.atlassian.net/rest/api/2/search?jql=project%3DUWS%20AND%20customfield_10803%3Dabcd&maxResults=2&fields='assignee,status,resolution'
So concatenating the search parameters to a string and url-encoding it instead of adding another field to the request.
Sam Huawey
What I usually do with REST search is first I try to put the JQL into the Advanced search in JIRA. As Joachim mentioned, your JQL is incorrect - it only searches for all of the issues in project UWS. What you really need is something like this:
project=UWS AND customfield_10803=abcd
If you enter this string in advanced searching, you will also have a chance to check the syntax. The '=' operator works with selections only, if your custom field contains text, you need to use '~'.
Jagjeet Randhawa
December 29, 2015
I already tried this before posting the question here :) However it gives me an error response saying"Field 'customfield_10803' does not exist or you do not have permission to view it." But I know that this field exists because this is in the response when I try using https://company.atlassian.net/rest/api/2/field . Part of Response: {"id":"customfield_10803","name":"Impacted Client(s)","custom":true,"orderable":true,"navigable":true,"searchable":true,"clauseNames":["cf[10803]","Impacted Client(s)"],"schema":{"type":"array","items":"option","custom":"com.atlassian.jira.plugin.system.customfieldtypes:multiselect","customId":10803}},
Deleted user December 29, 2015
As said, use the NAME not the ID
Deleted user December 28, 2015
Are you actually using the "Custom Field Name" name instead of the "Custom Field ID"? If not, can you try that?
Jobin Kuruvilla [Adaptavist]
December 28, 2015
What happens when you search using the same JQL in JIRA directly?
Help us plant more trees
