I am with LeTv. How do I log in now? I was able to 2 weeks ago.
Tim Berti January 6, 2016
3 accepted
Community moderators have prevented the ability to post new answers.
Post a new question
Steven F Behnke
January 6, 2016
Please open a request at support.atlassian.com. As indicated by Nic and Phill, this is a user Q&A forum, not a support portal for you to request your paid and included support from your Atlassian Cloud service.
Nic Brough -Adaptavist-
January 6, 2016
It's not "our" product. It's Atlassian's *Service*. They also provide this "Answers" site for the community of their users to talk and help each other out. Your link goes to a Cloud JIRA installation that Atlassian hosts, but it's actually *your* system. If you cannot log into it, and can't use the "reset password" options for some reason, then you need to contact your administrators. If you are an administrator, and you can't get in because the site is down, then raise a support request with Atlassian Cloud support (note that the "site down" pages all have a button to take you straight there)
Phill Fox
This is a forum for discussing issues with Atlassian products and without further information on which Atlassian product you are having problems with we are unlikely to be much help to you.
Post a new question
SUJIT KUMAR
May 18, 2018
Same problem
May 18, 2018
See the accepted answers.
Italo Qualisoni [e-Core]
January 6, 2016
@Tim Berti
When I try access this link: https://letech.atlassian.net/
We can see that shows a error and there is a Resolve issue button... have you seen this?
My thoughts are that your cloud server can be facing some internal issue and if this is the case you might open an issue to cloud support team..
Another point that might be causing your issue is some bill payment issue...
Either way, opening an issue to cloud support is the best option for identify the your root cause issue
Italo Qualisoni
Phill Fox
Your site is either currently undergoing an upgrade as part of the regular service provision or has become unusable. If the message does not clear then you should click on the support request button and fill in the details there.
image2016-1-6 19:21:22.png
This is the second day. I need to get into set people up.
January 6, 2016
Ah. Try clicking the "Create support request" then.
Phill Fox
As you state the message has been there for 2 days you should mention that when you raise your support request. This may then help you get a higher priority resolution. It is worth reviewing the page https://www.atlassian.com/cloud/security/ that tells you more about the service you have purchased.
Phill Fox
Did you get this sorted with support? Have you anything to share with the community about why it was not available?
HELLO!!!
Hemant patel
October 25, 2018
Please can you help me for login letv account I'm unable to login
October 26, 2018
Are you able to help me????
Do you have the link I need to login?
Anything.
Phill Fox
What service are you not able to login to?
Post a new question
