I can't get original estimate to appear on story entry screen
simonkardosh July 18, 2013
The field is added, but not visible
Raju KC
August 19, 2013
Add timetracking field in the screen. If present, make it visible from field configuration.
Timothy
July 18, 2013
simonkardosh August 19, 2013
Thanks, curiously when I use this, it tells me the field is on the screen even though I can't see it
