I want to add time spent gadget that grouped by worked user on my dashboard but I cannot see other users worklogs.
I need help, thank you
Check if you have required permissions on the project like browse, Work On Tickets
I will check permissions on the project
Thank you for your help and quick answer
Hello @Öznur Çakır ,
Are you using any plugin,
as of my knowledge, By default worklog related gadgets not available within Jira.
Anvesh Kagithala
Yes we are using plugin, I will check that plugin permissions. If I can't solve, I will write again
Thank you
and as @Rilwan Ahmed suggested please check the project permissions also and along with the JQL filter permissions.
