I cant create the issue
somanath kondeti February 5, 2018
We can't create this issue for you right now, it could be due to unsupported content you've entered into one or more of the issue fields. If this situation persists, contact your administrator as they'll be able to access more specific information in the log file.
Can anyone provide me the exact solution. I am trying find out the solution but i cant figure it out
Nic Brough -Adaptavist-
February 5, 2018
Don't put bad data into the fields.  It's going to be bad stuff in a text or label field.
To identify which one, please read the log, as the error suggests.  Or read the data.  The usual culprit is someone pasting in control characters or emojis copied in from an email or document.
Thanks for your reply.
Here, I am using Python scripts for the workflow. In that script , there is a condition when component is OARS then failed category is required except bug.
February 5, 2018
So, your scripts are putting rubbish in?  (Condition about things you row boats with seems to be utterly irrelevant to this question)
