I'd like to calculate time without setting a Goal
Luca Deboli
Hi to all,
is it possible to make Jira Service Desk count time without setting a Goal ?
I'd like to use the powerful Start/Pause/Stop SLA counting against working hour calendar but without a goal nor any red/green flags.
Thanks in advance.
Jack Brickey
A goal oriented SLA typically counts down as is the case w/ the current built in SLAs. It sounds like you want is a time counter that would count up but controlled by the start/pause/stop as you mention. This isn't possible OOTB. I would recommend check the Marketplace. A quick search yielded - enhancer-plugin-for-jira that may provide this but I have not experience w/ it so unsure. There could be others especially since you are on Server.
Luca Deboli
Thank you for your reply.
Tuncay Senturk _Snapbytes_
Hello @Luca Deboli , @Jack Brickey
Actually, Enhancer Plugin is removing SLA features soon which is announced here.
Instead of that, I strongly recommend using Time to SLA app.
Here is the comparison for both plugins regarding SLA features.
If you have any further info about SLA just raise a support ticket here.
Cheers
Like • Jack Brickey likes this
Jack Brickey
thanks for sharing @Tuncay Senturk _Snapbytes_
Like • Tuncay Senturk _Snapbytes_ likes this
Pleasure
Help us plant more trees
