I don't want issues to transition to done unless there is time logged.
Antonio Smith
November 2, 2022
So, like the question says... I want to make a rule where issues won't be able to transition to done unless there is time logged.
Kevin Dalton
Go to the workflow used in that issue type and for the close transition add a validator "Field Required Validator" and then select "Time Spent" field.
Also make sure for the close transition there is a transition screen with the "Time Spent" field incase it is not populated.
Hamza Chundrigar
November 2, 2022
I don’t think this is the right approach.
For example, say there are 3 statuses
  • To Do > In Progress > Done
  • User logs work while the ticket is in the ‘In Progress’ status/column so time spent on an issue is now > 0 (here OP’s condition would be satisfied since there has been time logged already. Adding a field required validator on the ‘Done’ status with a respective transition screen mandating the user to log time again when he has already done so in the past would not make sense then).
Kevin Dalton
If you have script runner you could try a simple script
issue.timeSpent || issue.modifiedFields.containsKey("worklog")
Or you could do something more complex with
import com.atlassian.jira.issue.ModifiedValue
import com.onresolve.scriptrunner.runner.util.UserMessageUtil
Map<String,ModifiedValue> modifiedValues = ((MutableIssue)issue).getModifiedFields()
return modifiedValues.containsKey("worklog") || (issue.timeSpent > 0)
 Both should check if time is logged or if the worklog is modified on the transition.
Antonio Smith
November 3, 2022
It looks like you're not able to add a validator when your project is Team-based and I don't think I'll get the budget to get a script runner. Any other options?
Here is what I have tried... there doesn't seem to be a way to check if the syntax is correct.
