When I create an issue if you fill all the required fields correctly work.
But when any of the mandatory fields not filled in, the validation to create an issue returns a 404 Bad Request.
Why the successful creation response works well and response from creation with validation errors no?
We have configured SSL on JIRA and redirect http to https.
Thank you very much.
Regards!
We had a problem with the proxy which was inserting its own error page when it received a 400 response.
Greetings.
you might need to change the Json content as Renjith mentioned in the link
Hi!
No, there is nothing.
I have seen the response to the request with the Firebug (Firefox).
hello Antonio Duarte,
are you having any exception list in the log or stack trace?
Learn more
