×When I use the following API call
http://www.example.com/jira/rest/api/2/user?username=f.per@servicerocket.com
I get all the users with a similar email to the one provided instead of the specified user.
In my example, I get these two users instead of the one related to the email
How can I get the specific user using the email address, is it possible?
Thank you in Advance
Hello @Felipe Perez _ServiceRocket_
Firstly, your question is about Jira DC, but you've also tagged your question with cloud and said it's a cloud deployment, which is putting the question in the wrong group and is confusing. Jira CLOUD is not Jira DATA CENTER.
The reason you're getting the results is because the string 'f.per@servicerocket.com' isn't a username, it's an email address.
If you want to search for a user based on their email address, use the Find Users endpoint, as it can search on email addresses
Hi David!
Thanks for the clarification on the tag that has been removed.
Regarding the "Find User" endpoint, I tried but got the same result,
this is my call:
http://www.example.com/jira/rest/api/2/user/search?username=f.per@servicerocket.com
Result:
I'll correct what you suggested to me and try again. thanks
Hi @Sunny Ape
Here is the new corrected question. I also tried what you suggested, but it didn't work. Any ideas?
What you are describing with the Find Users endpoint is a known bug that affects the Server / Data Center products. Refer to JRASERVER-72862.
Simply put, you are searching for a user who has an email address with a first part that matches another user's email address.
Either:
1. Do secondary filtering of the results from the endpoint to find the exact match, or
2. Stop using email addresses in user accounts that are identical in their fist part.
