I need a simple script to check if all linked issues which are "is blocked by" are resolved before r
tazeenn March 6, 2019 edited
I need a simple script to check if all linked issues which are "is blocked by" are resolved before resolving the issue
Ben Poulson
March 6, 2019
import com.atlassian.jira.issue.link.IssueLink;
import com.atlassian.jira.component.ComponentAccessor;
def allClosed = true
List<IssueLink> allInIssueLinks = ComponentAccessor.getIssueLinkManager().getInwardLinks(issue.getId());
for (link in allInIssueLinks)
if(link.issueLinkType.name == "Blocks")
def linked = link.getSourceObject()
if( linked.resolution == null) //You might need to modify this depending on how your project is set up
allClosed = false
return allClosed
 You might need to change how it determines if an issue is resolved depending on how your project is set up, but this should work.
thanks Ben, shall I add this as validator under simple validator script  in workflow transition
Ben Poulson
March 7, 2019
@tazeenn
Did it work? If so, could you mark my response as the answer?
tazeenn March 7, 2019
Hey Ben, It is not working.
I added this as validator in the transition however the ransiiton is not stopped if  an open blocked by link is available. Its still letting the issue closed
if( linked.resolution == Unresolved) //You might need to modify this depending on how your project is set up
allClosed = false
return allClosed
Ben Poulson
March 7, 2019
Delete the validator, then recreate it. Instead of choosing "Simple Scripted Validator", choose "Custom Script Validator".
ok. I will do that and let you know. I am marking it as answer for now
Hi ben,
I added in custom validator but still the code is letting the issue closed even though there is a "blocked by" issue linked to it'
Ben Poulson
March 15, 2019
Sorry, been a busy week, just saw this. I misunderstood your original problem- I thought you wanted to only allow the ticket to be closed if all the tickets blocking it were closed, not the other way around. To switch it, just change:
to
List<IssueLink> allOutIssueLinks = ComponentAccessor.getIssueLinkManager().getOutwardLinks(issue.getId());
You'll also need to change all uses of allInIssueLinks to use allOutIssueLinks instead. Other than that, you should be good to go.
Maksym Mishchenko February 20, 2024
If anyone finds this and it isn't quite working out for them.
replace
getSourceObject()
with
getDestinationObject()
because SourceObject is the issue you're in and not the issue on the other side of the link which you want to use for your validator.
tazeenn March 18, 2019
no luck:( Its still letting the issue close even thought the linked issue is open
