I need help copying the assignee field to a user picker custom field
Suzanne Seaton August 21, 2018
We want to copy the assignee field to a custom field named 'Responsible User(s)'. Thanks
Mark Markov
August 22, 2018 edited
Hello @Suzanne Seaton
I think you also need to save users that already exist in this field, so script should be like this
// a user custom field
def userCf = customFieldManager.getCustomFieldObjectByName("Responsible User(s)")
List<ApplicationUser> userAlreadyInCustomField = issue.getCustomFieldValue(userCf)
userAlreadyInCustomField.add(issue.getAssignee())
issue.setCustomFieldValue(userCf, userAlreadyInCustomField)
ComponentAccessor.getIssueManager().updateIssue(issue.getAssignee(), issue, EventDispatchOption.ISSUE_UPDATED, false)
Swarna Radha
 HI @Mark Markov,
I want to set the approver name in to a custom field B (mulitple user picker).
Is this possible?
Swarna
Mark Markov
August 28, 2018 edited
Yes is's possible. You can use script above with some modification.
You need getCustomFieldValue() method istead of getAssignee()
def fieldtoCopy = customFieldManager.getCustomFieldObjectByName("FromFieldName")
userAlreadyInCustomField.add(issue.getCustomFieldValue(fieldtoCopy))
Suzanne Seaton August 28, 2018
@Mark Markov, thanks so much for trying to help me. Unfortunately I get the following error on line 10 which is your line that states 'List<Application User> userAlreadyInCustomField = issue.getCustomFieldValue(userCf)
Here is the error: cannot assign value of type java.lang.Object to variable of type java.util.List (ApplicationUser)
Mark Markov
August 28, 2018
This is static type checking error you can ignore it. It will work :)
Alvin
October 1, 2018
Hi @Mark Markov , code does not working, it returns the error, I am trying to copy the current log in user to a single user pick custom field. How can I do that? Thanks
M November 15, 2019
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
def changeHolder = new DefaultIssueChangeHolder()
def cfMultiSelectUser = customFieldManager.getCustomFieldObjectByName("CC")
def cfMultiSelectUserValue = issue.getCustomFieldValue(cfMultiSelectUser)
((java.util.List)cfMultiSelectUserValue).add(currentUser)
cfMultiSelectUser.updateValue(null, issue, new ModifiedValue(cfMultiSelectUserValue, cfMultiSelectUserValue),changeHolder);
 The above code should have worked.
MG
Nic Brough -Adaptavist-
August 21, 2018
There's an example of setting lots of different field types over at https://scriptrunner.adaptavist.com/latest/jira/recipes/workflow/postfunctions/set-issue-attributes.html
On the section that sets the custom user-picker field, replace the "get user by name" function with a simple issue.getAssignee()
Although, I guess the field may be a multi-user picker.   Assuming you really want to add the assignee, not replace another or destroy the current list, then you will want to get the current value of the customfield (which will be a collection or list), add to it, and then poke the collection back into the field.
Thanks Nic, this is what I tried, and it's not successful:
def userUtil = ComponentAccessor.getUserUtil()
issue.setCustomFieldValue(userCf, issue.get.Assignee())
August 21, 2018
Is the field a multi-user picker?  The name suggests it might be?
Yes, it is a multi-user picker.
August 21, 2018
Ok, so the last paragraph applies, you need to treat it as a list.
Chander Inguva
August 21, 2018
This can be done using script runner or jira suite utilities plugins Suzanne.
Suzanne Seaton August 21, 2018 edited
Yes, I plan to use script runner (I tagged issue with groovy-script-runner). I need help with my groovy script. I found similar posts where use case was to copy custom field to the assignee field. This is opposite... copy the assignee to custom field. Thanks
