need to create more than 100 options with MLCS field.
is there any script or plugin I can use to fulfill this requirement ?
Sumit
Are you using Multi-Level Cascading Select Plugin? Have you tried this answer on old Atlassian Answers system?
Thanks .. this is similar to what I am looking for
In new MLCS version there is an option in 'System'/'Import from another system'
==> IMPORT from MLCS CVS
In v3.2.0 there is a bug, they corrected it (for me) in a v3.2.1 to appear shortly.
But you can also refer to:
https://answers.atlassian.com/questions/208043/how-to-update-a-mlcs-custom-field-through-rest
regards,
Franck
Register now
