I need to enable Resolution Field
Christian Puzder December 28, 2018
I have dug around on the community and cannot find an answer to this ...
Previously, when an issue was closed, the issue number had strikethrough. I liked this, I am the project owner.
Recently, that just stopped working, and I do not know why. Now, I cannot add the Resolution Field to my Issue screen.
Any guidance would be helpful
Tyler Brown
December 28, 2018
Hey Christian,
Best practice is to put a trigger or screen on the transition to where a resolution is required.
Hope this helps,
Tyler
Thanks Tyler ... and how do I do that? I used to have a PM that would do this stuff, but in my new venture, well, its just me managing Jira.
Tyler Brown
January 2, 2019
Hey Christian,
This documentation should help you out:
https://confluence.atlassian.com/adminjiracloud/advanced-workflow-configuration-776636620.html
You will be looking to add a post function to set the resolution.
Also you will need to be a system admin to complete this work.
Hope this helps,
Tyler
Christian Puzder February 26, 2019
Thanks Tyler
I did not see an option for what I need. Previously, when a story was closed in the backlog, the story number had a strikethrough. This was super helpful for me (product owner) to know which stories have been fully tested and closed.
Now when a story is closed, there is no strikethrough. I avae spent weeks going through the settings trying to find something helpful here and I can and my searches have not returned any valuable results.
Tyler Brown
February 27, 2019
Hey Christian,
That likely means that a Resolution is not being set.
There are a couple of options to help set a Resolution.
One is to create a screen with the Resolution field on it, and place it on the transitions where you want to set a Resolution.
These guides should help with that: https://confluence.atlassian.com/adminjiraserver/defining-a-screen-938847288.html
https://confluence.atlassian.com/jirakb/mapping-a-screen-to-a-workflow-transition-720634253.html
The other is to add a post function to set a Resolution automatically on your desired transitions.
This should help with that:
Tyler
Joe Pitt
NEVER add it to the edit or create screen. It is REQUIRED whenever presented. The field isn't enabled. It may be on a screen that used to be displayed on the close transition and isn't now.
