Hi all,
i got an requirement where i need to create a 4 different fields with same options, which is used in same project and issue type.
for Ex let says below is the filed name
accessory 1
accessory 2
accessory 3
accessory 4
are the four different filed with same option on them
like keyboard,mouse,usb....
This is not going to happen - every field is separate, they do not share their option lists.
Your choices are
The first and third options above won't solve the problem that the options are still all different items - i.e. item 1 on the master list named "Flibble" looks the same as item 1 on the other 3 lists also called "Flibble", but if you look at the database, you'd find four options called "Flibble" with ids like 10010, 10035, 10050 and 10100 - they're all separate and distinct options.
Hi Treethawat,
Thanks for the update,
i know how to create a custom fields, but my requirement here is to create 4 different fields with same options in all. so i want to keep one master copy that should reflect in all 4 fields.
i need to add some 200 options in each field with same option.
You just go to the custom field page and add them. (Keyboard shortcut: g + g + start typing custom fields)
Then link those fields to your screen.
Link: https://confluence.atlassian.com/display/JIRA/Adding+a+Custom+Field
Read the story
