I need to show a field on the basis of another. If click on one of the options on checkbox field the
Priyanka khare
Hello Community,
I need to show a field on the basis of another. If click on one of the options on checkbox field then the other field(date field) should be visible, if i have not
selected that particular check box then it should be hidden. I am using JIRA server version 8.5.0. How can i achieve this using script runner?
Regards
Priyanka Khare
Suvarna December 23, 2024
how can we do this kind of behavior without a script runner?
Derek Fields _RightStar_
You can create a Behaviour in Scriptrunner that will show or hide the field based on the value of the checkbox. Take a look at https://scriptrunner.adaptavist.com/latest/jira/tutorials/behaviours-tutorial.html
Haddon Fisher
October 9, 2020
If you've got ScriptRunner installed, then you can use the 'Behaviors' function to do this pretty easily. Adaptavist has an example in their library on how to do this, but their example is maybe a little more complicated than it needs to be. Here's my example, show\requiring two custom fields if the "Yes" option in the third field is selected. You may need to modify this some with a checkbox field, but this should get you pretty close.
// Get the fields you need
def triggerField = getFieldByName("Custom Checkbox Field")
def showField1 = getFieldByName("Custom Field 1")
def showField2 = getFieldByName("Custom Field 2")
// Evaluate the selected value; in this case, does it equal the string "Yes"
if(triggerField.value == "Yes"){
showField1.setHidden(false)
showField1.setRequired(true)
showField2.setHidden(false)
showField2.setRequired(true)
else{
showField1.setHidden(true);
showField1.setRequired(false);
showField2.setHidden(true);
showField2.setRequired(false);
Priyanka khare
Hello @Haddon Fisher
I need to be able to view the date field even if i select Yes and Na in my checkbox field.
For eg:
I have a checkbox field - Yes, No, NA and i want to-
1.show Date field when Yes is selected(even when yes is selected along with NA)
2. hide the date field if Yes is not selected at all.
Regards
Priyanka
Haddon Fisher
October 16, 2020
Hi @Priyanka khare , in that case you would just need to add a second 'if' clause to show the field if "NA" is selected.
Christina Braun
July 22, 2024
Hi @Haddon Fisher
An old case here but I am trying exactly the same for the create and edit screen.
My case: If in the Checkboxes field "Features" the value "Head-to-Head Test" is selected the Single Issue Picker field "DIGI Ticket" should get visible.
When using the code the "DIGI Ticket" is hidden but it does not get visible when selecting "Head-to-Head Test". Any idea what I'm missing?
Christina
Learn more
