I see invalid status of other work flow in an issue.
Shashi Jha September 14, 2015
Result after running integrity checker.
UNFIXABLE ERROR: The issue with key TA-72 has a status of Assigned which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-119 has a status of Product Fix Required which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-125 has a status of Assigned which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-93 has a status of Assigned which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-74 has a status of Product Fix Required which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-99 has a status of Waiting for Information which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-104 has a status of Product Fix Required which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-123 has a status of Assigned which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-73 has a status of Product Fix Required which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-124 has a status of Product Fix Required which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-87 has a status of Product Fix Required which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-75 has a status of Product Fix Required which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-105 has a status of Product Fix Required which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-97 has a status of Product Fix Required which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-86 has a status of Waiting for Information which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-102 has a status of Waiting for Information which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-92 has a status of Waiting for Information which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-88 has a status of Assigned which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-107 has a status of Assigned which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-89 has a status of Enhancement which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-76 has a status of Waiting for Information which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-94 has a status of Assigned which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-128 has a status of Assigned which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-78 has a status of Assigned which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-120 has a status of Under Analysis which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-106 has a status of Assigned which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-167 has a status of Implementation Fix Required which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-84 has a status of Waiting for Information which is not a valid status for the issues workflow. (JRA-8326)
UNFIXABLE ERROR: The issue with key TA-163 has a status of Implementation Fix Required which is not a valid status for the issues workflow. (JRA-8326)
Nic Brough -Adaptavist-
September 14, 2015
I'm pretty much with Jobin on this one - sounds like a very broken addon or external process, and something you need to remove immediately.
Except before trying SQL, I would try changing the workflow scheme for project TA - that might be able to repair it.
Jobin Kuruvilla [Adaptavist]
September 14, 2015
This can happen if the issues in question were updated by some plugin, without following all the necessary steps. Or the status was directly changed in the database.
You will have to fix the discrepancy in the database I am afraid!
Register now
