Sign up Log in
I want a Jira Intake form where users submit a form to automatically create an issue.
Chad Wood
August 26, 2024 edited
I want a way for users to submit requests that results in an issue being created automatically with the various fields (i.e. Epic Link, Component, Fix Version, etc.) filled out according to their respective submissions. Meaning, user inputs are collected via pre-selected options in a drop down menu &/or Radio buttons. Free-form text will not be used except for the Summary/Description.
To get this out of the way, I am working in a Jira Software project space so the Issue Collector feature will not work.
Currently, I have an Intake form in Confluence that has been mapped to Jira via email. This results in a Jira issue created systemically, however, all of the details provided in the intake form appear in the description of the newly created issue. Meaning I, or someone on my team, has to manually update each issue after it is created. Not the most strategic solution. I work in a very large organization with a high volume of requests. Manual work such as this is not a viable option. Any help is appreciated.
Brant Schroeder
August 26, 2024
@Chad Wood Welcome to the Atlassian community
You will need to use the Jira API.  This will allow you to create issue via the API and map fields to custom fields and only allow them to make specific selections.
https://developer.atlassian.com/server/jira/platform/rest/v10000/intro/#gettingstarted
Mila December 20, 2024 edited
Use Smart Forms for Jira to streamline your process. It lets you:
  1. Create Forms: Design forms with dropdowns/radio buttons for structured inputs.
  2. Automate Issue Creation: Automatically create Jira issues with pre-filled details.
  3. Embed in Confluence: Embed forms on Confluence (Guide).
Chad Wood
August 27, 2024
To add on to this for anyone that happens to stumble upon this page. I modified the Confluence intake form and set up automation rules in Jira to update the newly created issue systemically. This has helped my workflow but it is far from perfect. The data from the form still populates the description but at least I have some of the fields automatically updated so the new stories are bucketed appropriately.
I am looking into the API option that was suggested by Brant and will update this post if I am able to make any progress.
