I want that in tempo specific users should be able to approve timesheets of different people under t
Priyanka khare
Hello ,
I want that in tempo specific users should be able to approve timesheets of different people under them.
If in a tempo team I have 5 people(A,B,C,D,E) then I want that A should approve timesheet f B and C while D should be able to approve of E.
Is this hierarchy possible in tempo timesheet?
Regards
Priyanka
carolyn french
Hi Priyanka,
Another option to explore, especially if you don't need this to be restrictive:
You can set up the team with all 5 members. Give A and D the approve timesheet permission. Then you instruct each team member to select the appropriate reviewer (either A or D) for their timesheet approval.
Would that work for you?
Carolyn
Alexander Eck [Tempo]
October 26, 2020
Hi Priyanka,
you can´t setup a permission hierachy like this in Tempo. You only allow users to approve timesheets per team.
BR
