Hi dear atlassian community,
I want to build a perfect Roadmap connecting different project. I want to build a main project with sagas and connect these sagas to different epics from different project and then let me show the hierarchy in the Jira Roadmap.
How can I link a Saga with the Epic of another project? I tried the "link field" but nothing happened in the roadmap.
Thank you very much!
Maria
Hi @Mari Car ,
do I get it right your hierarchy levels are:
Please, make sure your configuration of hierarchy levels is correct (see Configure custom hierarchy levels)
Then you should be able to use Parent Link custom field in your Epics - in each Epic you should be able to select one Saga.
Hi @Hana Kučerová ,
thank you very much, yes my Hierarchi is:
Saga
Epic
Story
Task
I would like to have Epic children issues in the Saga, but I don´t get it. I can link a saga with an epic, but I want to make the epic as a child Issue. Can you help me?
Thank you very much and best regards,
Maria
Hi @Mari Car ,
I can see a problem with your hierarchy - Stories cannot be parents of Tasks, both need to be on the same level.
Anyway, if you want Saga issue to be parent of some Epics, you need to
