Hello, Need help
I have a request where customer wants a custom button named Create AC. when user clicks on it, it should t open create subtask issue dialog box and let the user create a subtask under a link type called "Acceptance criteria" and this button should be only available to feature issue type.
So far I used the xml raw script fragment from ScriptRunner to have a custom web item called create Acceptance Criteria and link it as a subtask.
below is the script to restrict the web item only to feature :
working script for a button to create subtask:
<web-item key='issuekey-123' name='ScriptRunner generated web item - Create Acceptance criteria' section='operations-restore' weight='1'>
<label>Add Acceptance Criteria</label>
<link linkId='link-create-constrained-subtask'>/jira/secure/CreateSubTaskIssue.jspa?parentIssueId=${issue.id}&pid=${issue.projectObject.id}&issuetype=14901</link>
<styleClass>issueaction-create-subtask</styleClass>
</web-item>
Yes, I used the ScriptRunner Fragment called Constrained issue web item custom button and behaviour script.
State of Product 2026: your pulse check on product development today. We asked 1000+ real teams how they’re feeling–and they had a lot to say.
Get the report
