I want to create a new project based on an existing workflow
Ken Jacobs
March 30, 2022 edited
How do I do this? I have a special workflow and do not want to use one of the Jira templates. It's been awhile since I created a project. What changed?
I am using the free version. BTW.
Benjamin
HI @Ken Jacobs ,
When you create a project, you can choose to shared the same template workflows as another project. If you created this special workflow on the side and haven't tied it to any project...then you would create a project and then afterward associate the workflow scheme.
Keep in mind that a workflow must be place in a workflow scheme before it can be applied to a project.
Here's the documentation:
https://support.atlassian.com/jira-cloud-administration/docs/manage-issue-workflows/
This is cloud but the same principal applies to server as well.
-Ben
Ken Jacobs
Wow! Thanks!
