×I'm not sure if it's okay to ask a question here, but may I ask a question?
As the same tasks (including subtasks) occur irregularly, I was considering preparing templates and creating tasks from them when they occur.
However, structured Gantt charts do not seem to have a template function, I am considering creating a task instead of a template and duplicating it.
When an existing task is duplicated, "Copy_" is automatically added to the beginning of the summary of the subtask, which is inconvenient to rename. Is there a way to duplicate the summary as is or any other good method?
Hello @takuya kanematsu ,
Welcome to the Community! It's always ok to ask a question here!!
Do I understand correctly that you are using Structure.Gantt by Tempo? If I have it right, the functionality isn't specific to Gantt, but to Structure. We have some documentation on how to Copy a Structure and Clone the Issues available.
This is only available for Server and Data Center instances at the moment. Your Tags show Server, so it should be available to you.
I hope this helps.
Best,
David
