I want to search for issue between time range in IE
jisun lee April 22, 2021
[Jira version]
8.5.12
[in advanced setting]
jira.date.picker.java.format = yyyy-MM-dd
jira.date.picker.javascript.format = %Y-%m-%d
jira.date.time.picker.java.format = yyyy-MM-dd HH:mm
jira.date.time.picker.javascript.format = %Y-%m-%d %H:%M
[in look and feel setting]
Time Format = h:mm a
Day Format = EEEE h:mm a
Complete Date/Time Format = yyyy-MM-dd h:mm a
Day/Month/Year Format = yyyy-MM-dd
When i search some issues between 2021-04-12 00:00 and 2021-04-28 00:00
on click the calendar,
popup this error message '텍스트를 12자 이하로 입력해야 합니다.'
this mean, 'The text must be 12 characters or less'
but, chrome, edge, firefox, .. no problem
only IE happen this issue
please solve it  T_T
Vikrant Yadav
April 23, 2021
Hi @jisun lee Instead of using Basic Search try Advanced Search which is easy to use , if you want to issue created under certain time frame try below JQL :-
project = "your-project-name" AND created >= "2021-01-01" AND created <= "2020-12-31" order by created DESC
 'createdDate' in formats such as: 'yyyy/MM/dd HH:mm'
OR
project=xyz and created  > startOfMonth() and created < endOfMonth()
or
https://community.atlassian.com/t5/Jira-questions/JQL-for-tickets-closed-within-a-time-range/qaq-p/348531
jisun lee May 12, 2021
thank you for your answer!! :)
but i have a another question
can't i change input length? my client want to use calendar
