IS Atlassian jira dll library v4.0.30319 supported for JIRA 7.4.6?
siddhesh
HI,
Atlassian jira dll library that we are currently using is v4.0.30319. Please check that this is compatible for the jira version v7.4.6? If not please let us know which atlassian jira library version is compatible. we need the dll dot net library
Earlier we were on jira 6.4.12. Over there the above dll library was working. But after upgrade we are facing some issues
Siddheshwar
DPKJ
September 16, 2019
@siddheshOn external interfaces Jira 6 used to have SOAP endpoints which were removed in Jira 7 in favor of REST endpoints.
You need to confirm that your DLL version have REST support.
Otherwise as mentioned on this SDK wiki page ( https://bitbucket.org/farmas/atlassian.net-sdk/wiki/Home ) you are running very old version of DLL. I suggest you upgrade your DLL to latest version and try.
siddhesh
Hi @DPKJ
 Thanks for your response.
How did I know that jira dll library v4.0.30319 supports REST?
Siddheshwar
DPKJ
September 16, 2019
@siddheshAs per information mentioned on change history page - https://bitbucket.org/farmas/atlassian.net-sdk/wiki/Change%20History
I can see that support for REST was added in 4.0.0 but later in version 4.5.0 more support was added. But I doubt that in this version they defaulted from SOAP to REST. You can confirm this by trying later version of DLL.
