I have automation to create stories that must exist in each sprint for specific people. It is beneficial to include the sprint name in the story's summary. I cannot figure the json or smart value to use to append that data.
This is the automation to create the story. The sprint name needs to appear after "KLO On-call" in the Summary field.
This is for the story created using the above automation. It successfully placed it in the next sprint "AUG24-18 Letters 8/28-9/10".
How can I get that information to also appear in the Summary field?
{ "expand": "renderedFields,names,schema,operations,editmeta,changelog,versionedRepresentations", "id": "1569958", "self": "https://enterprise-jira.onefiserv.net/rest/api/2/issue/1569958", "key": "OSPLT-3660", "fields": { "customfield_15400": null, "customfield_15401": null, "customfield_10110": null, "fixVersions": [ { "self": "https://enterprise-jira.onefiserv.net/rest/api/2/version/51163", "id": "51163", "name": "No Release", "archived": false, "released": false } ], "customfield_11200": { "self": "https://enterprise-jira.onefiserv.net/rest/api/2/customFieldOption/15600", "value": "🟩 Green", "id": "15600", "disabled": false }, "customfield_10111": null, "resolution": null, "customfield_15403": null, "customfield_11831": null, "customfield_10106": [ "com.atlassian.greenhopper.service.sprint.Sprint@3b3928f4[id=18342,rapidViewId=4784,state=FUTURE,name=AUG24-18 Letters 8/28-9/10,startDate=2024-08-28T13:21:00.000Z,endDate=2024-09-11T13:21:00.000Z,completeDate=\u003Cnull\u003E,activatedDate=\u003Cnull\u003E,sequence=18342,goal=\u003Cnull\u003E,synced=false,autoStartStop=false,incompleteIssuesDestinationId=\u003Cnull\u003E]" ], "custom
Welcome to the community.
After the issue creation, add a branch in your automation based on most recent created issues and then edit the summary field.
To append the information set the summary as follows {{issues.summary}} - {{issues.sprint}}
Hello @Jill Fitzgerald
Do you know if Sprint will be active (started) when this automation were to run? That determines if you have access to the open sprint..
Also, not only that a sprint is active, there must be stories in the sprint.. then we can do lookupIssues and get the sprint name...
