If I create user using userUtil.createUserNoNotification, how can I add it?
Deleted user April 17, 2014
hello
I'm using 6.1.6 API
howevr I don't know how to add users using JAVA
is this right source below?
File f = new File(".txt File Path");
       BufferedReader br = new BufferedReader(new InputStreamReader(new FileInputStream(f)));
       String[] array = null;
       String text = null;
       while ((text = br.readLine()) != null)
       array= text.split("\t");
      User a = userUtil.createUserNoNotification(array[0], array[3], array[1], array[2]);
When I use that source code , I got NullPointerException...
How to handle it?
Please give me the way
Boris Georgiev [Appfire]
April 17, 2014
Do you execute that code from inside a plugin or you've just created a Java class and want to add users ?
If you're not inside a plugin this code will not work and you should consider creating users using the REST api through the Jira Java Rest Client
https://bitbucket.org/atlassian/jira-rest-java-client
April 17, 2014
Also it's generraly a good practice to also include part of the exception when you ask a question, so it's visible exaclty where the exception is thrown
