×If we are creating child under epics using issue link option by default showing only issue key sumarry and priority option as columns
But if we want to see additional columns there how to bring that.
Hi @Priya ,
Customizable columns are coming to Jira, we just don't know how and when exactly it will be available for all users: https://community.atlassian.com/t5/Jira-questions/jira-subtask-view-in-parent/qaq-p/2924536
Hi @Priya
You may want to look at a mktplace app for this requirement. We have built an app for the same use case.
The app allows you to create/view your hierarchy based on your issue links. You can view %complete progress at each parent level. The app has multiple features as below :
- Sum up values to see overall progress for your Issue Hierarchy
- View the full hierarchy of linked issues, Portfolio/Advanced Roadmaps, Epics, and Subtasks
- Apply filters to put the focus on the relevant data only
- Excel like editing for all the values right on the report and see real time progress updates
- Export to a CSV file
- Embedded Epic Hierarchy on Issue Screen
- Dashboard Gadgets
(Disclaimer: I work for RVS, the vendor for this app)
Hi @Priya,
I believe you are looking for this? https://jira.atlassian.com/browse/JRASERVER-36490
As the ticket suggests, this isn't currently possible. I would recommend watching and perhaps upvoting the feature request.
Alternatively, if you're open to solutions from the Atlassian Marketplace, you should get pretty close; see e.g. this thread for possible directions forward.
Best, Hannes
Hello @Priya
Based on my understanding, Jira’s default issue link view only displays essential columns like issue key, summary, and priority.
If you want to add more columns, you may need to customize the view through Jira’s administration settings or leverage a marketplace app that allows advanced issue linking and display customization.
