Our Jira and LDAP Active Directory (Microsoft) are integrated.
As a company policy, we never delete users from our AD, but disable them.
However, in Jira I see all users (both enabled and disabled).
How do I configure my Jira to ignore disabled users?
Janiv.
You could perhaps filter by the LDAP attribute userAccountControl...
Based on Microsoft Support's explanation:
The attribute that holds this information is the userAccountControl attribute. This attribute is composed of a combination of different flags. The flag for setting the object that you want to disable is UF_ACCOUNTDISABLE, which has a value of 0x02 (2 decimal). The bitwise comparison filter that specifies userAccountControl with the UF_ACCOUNTDISABLED bit set would resemble this:
(!(UserAccountControl:1.2.840.113556.1.4.803:=2))
...would be all accounts that are not disabled.
So, in JIRA Admin | Users | User Directories
Select your AD configuration then expand the User Schema Settings heading
In the User Object Filter field, paste something like...
(&(objectCategory=Person)(sAMAccountName=*)(!(UserAccountControl:1.2.840.113556.1.4.803:=2)))
This is the default filter for AD with the additional filter added.
Or the selected field here:
Where do I put this string in Jira?>
Thanks again,
The interesting question is how to disable Jira users which are disabled in active directory (to see them as disabled)
Where does the syntax (!(UserAccountControl:1.2.840.113556.1.4.803:=2)) come from? What is the meaning of those numbers? Active Directory has a normal looking syntax with named flags, shouldn't we be able to use something like (!(UserAccountControl & UF_ACCOUNTDISABLE = UF_ACCOUNTDISABLE)) or, lacking symbolic bitmasks, (!(UserAccountControl & 0x02 = 0x02))?
@Andrew Eldredge those numbers are object identifiers. You can't find more info here: https://technet.microsoft.com/en-us/library/cc961749.aspx
I already tried this and ended up having bigger problems: this filter removes people from the LDAP results and due to this Jira will remove all their group memberhips. That's by (bad) design, and even if the account is re-enabled, the users group membership is not going to be restored.
If jira would just diable the users it would be OK, but that's not what it really does.
Note: this is also happening if they forgot to change their password every 3 months! Try to scale the problem to >100 users and you are already a doomed jira admin.
