Implement database connection pool monitoring in Centreon
Wajih Zouaoui November 19, 2024
Hello dear community,
please i want to ask if it's doable to implement a monitoring system for the database connection pool in Centreon ?
We are using the built in tool in Jira but we need to add something similar to our dashboards in Centreon .
Thank you in advance.
Best Regards,
Wajih
meliodas16
November 25, 2024
Hello @Wajih Zouaoui
In order to be able to monitor the DB connection pool via Centreon, you should use the jvm agent required by Centreon : https://jolokia.org/agent/jvm.html
You can download the JVM-Agent listed here : https://jolokia.org/download.html.
Once done, add the following argument to Jira startup arguments and restart Jira :
-javaagent:<full-path-to-jvm-jollokia-jar>=port=8778
To test if it's functioning you can access:  server-ip:8778/jolokia/
To have the number of idle/active connection :
  • NumActive:
http://127.0.0.1:8778/jolokia/read/com.atlassian.jira:type=metrics,category00=db,category01=connection,category02=pool,category03=numActive,name=valuection pool,
  • NumIdle:
http://127.0.0.1:8778/jolokia/read/com.atlassian.jira:type=metrics,category00=db,category01=connection,category02=pool,category03=numIdle,name=value
Don't forget to adjust the 127.0.0.1 to your current ip/hostname/domain.
To have the connection set-up on Centreon, please follow this doc: https://docs.centreon.com/pp/integrations/plugin-packs/procedures/applications-jvm-jmx/
Hope it helps !
Kind regards.
Wajih Zouaoui November 25, 2024
Hello @meliodas16 ,
thank you a lot for your reply, i really appreciated that.
So if i'm really understanding that this agent can use the jmx already exposed like dbconns, users, projects  and it can be linked to Centreon ? is there any documentaions with the full links with other metric slike you have mentioned above ( ex:  com.atlassian.jira:type=metrics,category00=db,category01=connection,category02=pool,category03=numIdle,name=value )
Best Regards,
Wajih
I think i found it here https://confluence.atlassian.com/adminjiraserver0820/live-monitoring-using-the-jmx-interface-1095777569.html
Thank you again and much respect for your help
Best Regards,
Wajih
Wajih Zouaoui November 26, 2024 edited
One more question please, if we have a cluster with multi nodes, do we need to install the agent only in 1 node ?
Read the story
