I am executing the command below in the JIRA User Guide
But I get the following error
Regards
Deepak Bhatia
[root@localhost ~]# keytool -import -alias tomcat -file file.cer
Enter keystore password:
keytool error: java.lang.Exception: Certificate reply and certificate in keystore are identical
your command only trys to import the cert to your local keytore (on windows User/USERNAME/.keystore). In this keystore the tomcat file is already existing.
You Should add the certificate to your JIRA's JRE.
keytool -import -file tomcat.cer -alias tomcat -keystore "%JAVA_HOME%\lib\security\cacerts"
But Attention, if your are using a JDK for your JIRA (i think you ever need a jdk to run JIRA) you have to use the "jre" folder in your JDK
keytool -import -file tomcat.cer -alias tomcat -keystore "PATH_TO_JDK\jre\lib\security\cacerts"
If you want do change the certificate in your local keystore you have to remove the old one proviously
keytool -delete -alias tomcat
Don't forgot to restart your JIRA after changes :)
how can restart JIRA ,whitch command must be run to restart JIRA
To restart JIRA try following:
C:\Program Files\Atlassian\JIRA\bin>stop-jira.bat
C:\Program Files\Atlassian\JIRA\bin>start-jira.bat
Change your path accordingly.
Hi.
Is it necessary set JAVA_HOME? In my Jira's installation isn't
Regards
I am mhlaba can anyone please assist as we trying to re-new a certificate for JIRA. we have already received the certificate but we trying to install it on JIRA but the is no luck.
can anyone assist?
hi...did this work..i,m trying to import .pfx file. it doesnt work..any luck?
