You can import the Excel format into another JIRA instance using the import utility. If the configurations are different on both, you might be asked do some config during the import.
Run your search and look above the list of returned issues - you'll see options for Excel, Word, RSS and XML feeds...
thanks a lot for your replies both.
So I need to export my issues list in Excel format and then reimport this file with the administration project import utility - is that right please ?
yeah, that's right.
