Importing CSV causes error
John Di Ciurcio
When user attempts to import a CSV file the following error is displayed:
An error occurred whilst rendering this message. Please contact the administrators, and inform them of this bug. Details: ------- org.apache.velocity.exception.MethodInvocationException: Invocation of method 'getIssueTypes' in class com.atlassian.jira.plugins.importer.imports.csv.web.CsvValueMappingsPage threw exception java.lang.NullPointerException at com.atlassian.jira.plugins.jim-plugin:actions//templates/admin/views/csv/csvValueMappingsPage.vm[line 101, column 51] at org.apache.velocity.runtime.parser.node.ASTIdentifier.execute(ASTIdentifier.java:223) at
Any ideas? Thanks.
Matheus Fernandes
May 9, 2018
Hi, @Mark Sanders / @John Di Ciurcio
It looks like you are hitting into a bug in Jira when mapping the Issue Type field during the CSV import: JRACLOUD-68491. As a workaround please try removing the issue type from the mapping option. Alternatively, you can try importing the CSV using the Import to Jira Project option rather than mapping the project in the CSV (this should also work, we'll test this option and update the bug report accordingly if it does).
Cheers!
Omar Sood
November 5, 2019
Is there any way to exclude entries from the import then, when importing to a specific project? To split multi project import is quite laborious.
Johan Hultberg
September 12, 2023
More than 5 years has passed and I still have this problem
Hector Eduardo Calzada Tenorio
The problem is with the language in the Issues. I had a task Issue Type in two languages and when importing that was the error because it updated from task to tarea (in spanish)
Work on homologating your Issues from your workflows so that they do not have this error or do not select the Issue Type of incident in "Map Field Value"
Tabbish Noorani March 5, 2022
Hi guys. Try to change the name of the issue type and revert it back. This resolves the issue.
Jim Edgeton
September 2, 2022
Hi @Tabbish Noorani can you provide more specifics to this workaround?
Yash Doshi April 19, 2021
Still waiting for a resolution
Hi @Yash Doshi. Try to change the name of the issue type and revert it back.
Austin Powell
April 6, 2021
I too have encountered this bug. Still no solution after 2 years?
Jose_Ramirez
January 13, 2020
Affected by this as well.
Murugan Mittapalli
I am having the same issue, getting an error when I map the issue type field.
Thank you.
Omar Sood
November 5, 2019
Any news on this one? The issue type mapping renderer is still broken
Kevin Delord August 21, 2019 edited
I am having this issue as well. The CSV importer gives a warning if no issue type is given.
Ben Hunnicutt October 22, 2018
I selected the "JIRA Field" (Issue Type to Issue Type) but did not check the "Map Field Value"  I was updating start and due dates.  This worked for me.
Facing the same issue now.  Bug not fixed.
Katie
June 22, 2018
This bug ha not been fixed. Facing the same issue now.
Mark Sanders
March 1, 2018
I'm facing the very same issue right now. Did you find a solution?
Register now
