Importing XML Backup
Richard Lane August 21, 2015
Good Afternoon,
I am a newbie to JIRA and have exhausted online resources trying to get the import working.
I have backed up our LIVE JIRA and wanted to import this into our test environment.  As best as I can. I had used the same setup to create an test environment in AWS with only one exception.  Live system uses SQL Server but our AWS test environment is currently using MYSQL.
Every time I try and import the XML file, the import gets to around 56% and then crashes with the following error message:
Error importing data: org.xml.sax.SAXException: com.atlassian.jira.exception.DataAccessException: org.ofbiz.core.entity.GenericEntityException: while inserting: [GenericEntity:Action][updateauthor,phillips][issue,10977][author,phillips][created,2009-03-10 14:53:29.8][id,14630][type,comment][body,This same error has occurred on OFFDC01: Event Type: Warning Event Source: MSDTC Event Category: SVC Event ID: 53258 Date: 10/03/2009 Time: 9:21:15 AM User: N/A Computer: OFFDC01 Description: MS DTC could not correctly process a DC Promotion/Demotion event. MS DTC will continue to function and will use the existing security settings. Error Specifics: d:\nt\com\complus\dtc\dtc\adme\uiname.cpp:9351, Pid: 1384 No Callstack, CmdLine: C:\WINDOWS\system32\msdtc.exe For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Data: 0000: 05 00 07 80 ...€ ][updated,2009-03-10 14:53:29.8] (SQL Exception while executing the following:INSERT INTO jiraaction (ID, issueid, AUTHOR, actiontype, actionlevel, rolelevel, actionbody, CREATED, UPDATEAUTHOR, UPDATED, actionnum) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) (Incorrect string value: '\xC2\x80 ...' for column 'actionbody' at row 1)) java.lang.Exception: com.atlassian.jira.exception.DataAccessException: org.ofbiz.core.entity.GenericEntityException: while inserting: [GenericEntity:Action][updateauthor,phillips][issue,10977][author,phillips][created,2009-03-10 14:53:29.8][id,14630][type,comment][body,This same error has occurred on OFFDC01: Event Type: Warning Event Source: MSDTC Event Category: SVC Event ID: 53258 Date: 10/03/2009 Time: 9:21:15 AM User: N/A Computer: OFFDC01 Description: MS DTC could not correctly process a DC Promotion/Demotion event. MS DTC will continue to function and will use the existing security settings. Error Specifics: d:\nt\com\complus\dtc\dtc\adme\uiname.cpp:9351, Pid: 1384 No Callstack, CmdLine: C:\WINDOWS\system32\msdtc.exe For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Data: 0000: 05 00 07 80 ...€ ][updated,2009-03-10 14:53:29.8] (SQL Exception while executing the following:INSERT INTO jiraaction (ID, issueid, AUTHOR, actiontype, actionlevel, rolelevel, actionbody, CREATED, UPDATEAUTHOR, UPDATED, actionnum) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) (Incorrect string value: '\xC2\x80 ...' for column 'actionbody' at row 1))
The error message appears to indicate insert issues therefore I assume has something to do with the data.  I had ran the clean up tool advised here but with no joy.
 https://confluence.atlassian.com/display/JIRA063/Removing+invalid+characters+from+XML+backups
Could someone provide any advise as to what I am missing or doing wrong please?
System Info:
Base URLhttp://jira.Test.local
System DateFriday, 21 Aug 2015
System Time23:39:29 +1000
Current Working DirectoryD:\JIRA\JIRA
Java Version1.8.0_11
Java VendorOracle Corporation
JVM Version1.8
JVM VendorOracle Corporation
JVM Implementation Version25.11-b03
Java RuntimeJava(TM) SE Runtime Environment
Java VMJava HotSpot(TM) 64-Bit Server VM
User NameSYDVJIRA01$
User TimezoneAustralia/Sydney
User LocaleEnglish (Australia)
System EncodingCp1252
Operating SystemWindows Server 2012 6.2
OS Architectureamd64
Application Server ContainerApache Tomcat/7.0.55
Database typemssql
Database JNDI addressmssql jdbc:jtds:sqlserver://SQL:1433/JIRA
Database URLjdbc:jtds:sqlserver://SQL:1433/JIRA
Database version10.50.6220
Database driverjTDS Type 4 JDBC Driver for MS SQL Server and Sybase 1.2.4
External user managementOFF
JVM Input Arguments-Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory -Dcatalina.home=D:\JIRA\JIRA -Dcatalina.base=D:\JIRA\JIRA -Djava.endorsed.dirs=D:\JIRA\JIRA\endorsed -Djava.io.tmpdir=D:\JIRA\JIRA\temp -Datlassian.plugins.enable.wait=300 -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.util.logging.config.file=D:\JIRA\JIRA\conf\logging.properties -XX:MaxPermSize=384m exit -Xms512m -Xmx2048m
Modified Files[Installation Type: Standalone] templates/email/subject/issueresolved.vm, templates/email/subject/issuecreated.vm, hash-registry.properties, templates/email/subject/issuereopened.vm, templates/email/subject/issueclosed.vm, templates/email/subject/issueworkstopped.vm, templates/email/subject/issuenotify.vm, templates/email/subject/issueassigned.vm, jira-application.properties, templates/email/subject/issueworkstarted.vm, templates/email/subject/issuedeleted.vm, templates/email/subject/issueworklogdeleted.vm, templates/email/subject/issuecommentedited.vm, templates/email/subject/issueworklogupdated.vm, templates/email/subject/issueupdated.vm, templates/email/subject/issueworklogged.vm, templates/email/subject/issuecommented.vm, templates/email/subject/issuemoved.vm
Removed Files[Installation Type: Standalone] There have been no removed files
ClusteringOFF
Luciano Fagundes
August 21, 2015
Phillip,
I can see the following error at the end of the stack trace  (Incorrect string value: '\xC2\x80 ...' for column 'actionbody' at row 1)).
Could you please confirm if you've created the database using the correct collation?
Collation type must be case-insensitiveaccent-insensitive, and language neutral for example, 'SQL_Latin1_General_CP437_CI_AI' is a case-insensitive, accent-insensitive, and language neutral collation type
This is described on our Connecting JIRA to SQL Server Database documentation.
Another thing that may cause this is that you've invalid characters on your XML Backup. That being said, please follow our Removing invalid characters from XML backups documentation. After that, please reimport again and let us know how it goes. smile
Hope it helps!
 Cheers
L.F
Richard Lane August 25, 2015
@Michael Ngangom
Thank You but I had tried the SQL 2008 R2 bit on the page but with no joy.  The JTDS.. I was using 1.3.1 but had downgraded to 1.2.4 now and still getting the same error.
michael_ngangom
August 25, 2015
Did you try to do this: Drop JIRA's database and follow the steps on Connecting JIRA to a Database to ensure the database and database user have been properly configured.
@Michael Ngangom Hi Michael, Yes, tried both MySQL and SQL, both connect fine with JIRA. The issue only occurs when trying to connect to existing Database. I assume the Jira version had been upgraded many a times but the DB always stayed the same therefore DB might contain previous data which might not be valid with current jira version.
michael_ngangom
August 25, 2015
Hello Philip, There are other way to restore system (by restore I mean taking the backup to a new clean installation). You can try by creating a DB DUMP and using it in the new system- hopefully this will work. Do let me know the result
Richard Lane August 26, 2015
@Michael Ngangom Thank you for your help. I have now managed to get XML Backup working on our Test environment. Had to use the script generator to create a script on Live DB instance. Ran the file on test DB instance, which created all the tables and columns. Connected TestJira to the DB instance and configured Jira. Once logged in, i was able to use the XML backup from Live to restore.
mngangom August 26, 2015
cool! @Philip Scott
michael_ngangom
August 26, 2015
cool! @Philip Scott
michael_ngangom
August 25, 2015
Helo,
Try this. This looks similar and I hope you have installed JTDS driver as well according to what is mentioned in the supported platforms page
Hi All,
I have rolled out an AWS EC2 with SQL 2008 R2.
I have re-installed JIRA 6.3.8 and the connection between the 2 seems fine.
I have backed up our 'Live' JIRA from another SQL 2008 R2 and restore the DB to AWS EC2.
Checked all these and done the best I can to adjust to meet what has been advised here:
https://confluence.atlassian.com/display/JIRA/Connecting+JIRA+to+SQL+Server+2008
Now after the Admin account setup page, I am getting the followqing error;
Cause
Referer URL: http://localhost:8080/secure/SetupAdminAccount!default.jspa
java.lang.RuntimeException: com.atlassian.jira.exception.CreateException: com.atlassian.crowd.exception.runtime.OperationFailedException: No Crowd Application available.
	at com.atlassian.jira.web.action.setup.SetupAdminAccount.doExecute(SetupAdminAccount.java:236)
	at webwork.action.ActionSupport.execute(ActionSupport.java:165)
	at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:88)
	at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39)
	at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31)
	at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16)
	at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35)
	at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:225)
	at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:154)
	at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:152)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87)
	at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:22)
	at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
	at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70)
	at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:39)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
	at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38)
	at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
	at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37)
	at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:36)
	at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60)
	at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92)
	at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56)
	at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
	at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:103)
	at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:87)
	at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:45)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:181)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:85)
	at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124)
	at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)
	at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:239)
	at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:100)
	at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:172)
	at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
	at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:69)
	at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
	at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
	at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
	at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
	at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
	at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
	at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)
	at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:82)
	at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:59)
	at com.atlassian.jira.web.filters.gzip.JiraGzipFilter.doFilter(JiraGzipFilter.java:55)
	at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:41)
	at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
	at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
	at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
	at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:79)
	at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(MultipartBoundaryCheckFilter.java:41)
	at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:60)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1070)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:611)
	at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
Caused by: com.atlassian.jira.exception.CreateException: com.atlassian.crowd.exception.runtime.OperationFailedException: No Crowd Application available.
	at com.atlassian.jira.user.util.UserUtilImpl.createUserInDefaultDirectory(UserUtilImpl.java:277)
	at com.atlassian.jira.user.util.UserUtilImpl.createUserInDirectory(UserUtilImpl.java:302)
	at com.atlassian.jira.user.util.UserUtilImpl.createUserNoNotification(UserUtilImpl.java:292)
	at com.atlassian.jira.bc.user.DefaultUserService.createUserNoNotification(DefaultUserService.java:355)
	at com.atlassian.jira.web.action.setup.SetupAdminAccount.doExecute(SetupAdminAccount.java:180)
	... 184 more
Caused by: com.atlassian.crowd.exception.runtime.OperationFailedException: No Crowd Application available.
	at com.atlassian.crowd.embedded.core.CrowdServiceImpl.addUser(CrowdServiceImpl.java:290)
	at com.atlassian.crowd.embedded.core.DelegatingCrowdService.addUser(DelegatingCrowdService.java:85)
	at com.atlassian.crowd.embedded.core.FilteredCrowdServiceImpl.addUser(FilteredCrowdServiceImpl.java:51)
	at com.atlassian.jira.user.util.UserUtilImpl.createUserInDefaultDirectory(UserUtilImpl.java:254)
	... 188 more
Hi Michael,
Sorry I don't know if I fully understand.
Live system is hosted locally but I would like to automate the 'replication' so that we have a weekly refresh in AWS environment.  Don't want to mix both environment together.
Tried the DB DUMP but using MySQL WorkBench to transfer the data to MYSQL seem to throw up an error.  Not sure if this is caused by the internet lag and the size of the DB.  I am currently creating a AWS EC2 with SQL and see if I can get this up and running.
Long term, prefer to address the import issue as this will make the Jiratest refresh that much simpler.
michael_ngangom
August 21, 2015
Why don't you connect directly your JIRA_HOME from your JIRA instance- or take a DB DUMP and do it that way as well.
