I have run a test import from Bugzilla into JIRA but the QA Contact field was not imported. Looks like a couple of other fields are also missing. Is there a work around for this issue?
I'm facing the same issue... test import missed "QA Contact" field during Bugzilla to Jira import. Is there a work around for this issue?
I have just completed the migration of our Bugzilla system into JIRA and am not aware of this field in Bugzilla.
Even if it is a custom field I'd expect the importer to pick it up.
I did this all OK on 6.3.12 of JIra
