Hi All,
I am upgrading my Jira from 4.3.2 to 5.1.8. I have my reporter field as read-only field for couple of transitions.
I wanted to make this reporter field as read-only in Jira 5.1.8 also. But when I install compatible version for Jira 5.1.8 i.e. Behaviour Plugin 0.5.3. then reporter field or any other user picker is not made as read-only.
This is a Bug for Behaviour Plugin. Can anyone please tell me the workaround for this?
Any help will be appreciable...
Thanks in Advance.
Renu
What i would suggest you is write a groovy script which will add a helptext to the reporter field using setHelpText(String helptext). the help text will be the below javascript . You will need to escape it as a string :) like this you can make the field readonly only on transitions you want
<script type="text/javascript"> AJS.$(document).ready(function(){ AJS.$("#reporter-field").attr("disabled",true);});</script>
Hope this helps
Hi Mizan,
Thanks for replying.
I checked your script but sometimes it is not working.For some screen it is hiding reporter field.
Can you please tell why it is happening? & I want this for some transitions if I apply it on description it will be applied globally.
Thanks & Regards,
Renu
You've already reported this as https://studio.plugins.atlassian.com/browse/JBHV-184 ... ?
Reporting it in multiple places is not going to make me look at it any faster.
Hi Jamie,
I know that you can not look into it faster. but I just wanted some workaround if anyone else knows it that is why I put this on the answers.
Because my client wants immediate solution for this.
If you could suggest any solution for this then it would be great for me.
Thanks & Regards,
Renu
Get your free all-access digital pass and don’t miss groundbreaking announcements, brand new features and product updates, insight-packed sessions, and exclusive digital content.
Sign up
