In JIRA 4.4.5 SMTP configuration option is missing/disabled? How to enable it?
sam engr May 22, 2012
Hi We were using jira 4.3.1 with pop configured server. I upgraded server to jira 4.4.5 now. Everything seems working apart from mail. I have to configured smtp server not pop/imap. When I go to Administration : Administration > System > Mail > Mailservers. The only option I get POP/IMAP not smtp server. It doesn't display the "Add SMTP Mail Server" screen.
I am not sure if it is disabled somewhere or missing plugin?
I am using RHEL Linux 5.8. and built jira war file as mentioned on jira4.4.5 documentation. (not using standalone version)
Can any body help me to sort this out?
Cheers
Jobin Kuruvilla [Adaptavist]
May 22, 2012
You need to be a JIRA System Administrator to add SMTP server. I am guessing you are only a JIRA Administrator.
http://confluence.atlassian.com/display/JIRA/Managing+Global+Permissions#ManagingGlobalPermissions-AboutJIRASystemAdministratorsandJIRAAdministrators
Thanks for answering. Exactly that was the issue.
cheers
