In JIRA 5.0 Javascript onchange embedded no longer works if you change issue type or project
Dana Frost
Here is an example of some Javascript that works well in JIRA 4.x but no longer works in 5.x when you create issues due to the changes in way the create (type/project) changing works. The Javascript seems to work UNTIL you change the project or type then it no longer appers to fire. Its strange because it will work if you don't change the project/type or if you open the "Create" window in a new tab but not if the default sub-window is used (with the project/type change at the top).
EXAMPLE of an onchange javascript hook that no longer words in JIRA 5.0
<script type="text/javascript" charset="utf-8" id="setCandidateRelnote">
document.getElementById("customfield_10403").onchange = function() {
if ( document.getElementById("customfield_10403").selectedIndex == 2 ||
     document.getElementById("customfield_10403").selectedIndex == 3 ||
     document.getElementById("customfield_10403").selectedIndex == 5 ||
     document.getElementById("customfield_10403").selectedIndex == 6) {
     document.getElementById("customfield_10306-1").checked = true;
</script>
JamieA
April 12, 2012
Same as the other question, answer is in https://developer.atlassian.com/display/JIRADEV/Custom+Fields+that+use+CSS+or+JavaScript+Web+Resources+in+JIRA+5.0.
Use a live() handler for "change" or bind to JIRA.Events.NEW_CONTENT_ADDED.
Dana Frost
Thanks. I found that page after some more searching. Seems like I have a bit of work to do :)
Let's build A Rovo Agent 🤖
Save your spot
