In Jira 5.0, if we change to an issue's description, the notification mail comes html code. What is the problem?
Harun Çetin July 2, 2012
I can not solved to this problem. Can you help me if you know the solution?
5 votes
Dieter
July 6, 2012
Penny Wyatt (On Leave to July 2021)
April 18, 2013
We've had issues in older JIRA versions where if the issue summary contains a newline character, the HTML emails can get corrupted. e.g. https://jira.atlassian.com/browse/JRA-27343
Adding newlines to issue summaries isn't possible through the UI, but if issues are created from plugins or via the API, it's possible to get bad data in.
Perhaps try deleting and completely retyping the issue summary to get rid of any invisible newline characters that could have slipped in?
Higashi
September 13, 2012
Go to Profile and change email notification to clear text notification
Register now
