I know I can edit the labels with L keyboard shortcut. Is there a way to edit Component field with keyboard shortcut?
thanks
Nope, labels are special system fields :)
But you can edit the issue by typing 'e' and then modify the components.
I wish it was easier but this is also helpful. E and 3 tabs does it for me.
I've always found the period (.) shortcut to be super helpful in modifying any field on a ticket. Type in period and start typing Component to find the field to edit.
Neat! This worked for me. Thanks.
