×I am trying to import a CVS with 101 records into a predefined structurer in insight
I have my IQL mapped properly and it is the same attribute structure as another part of insight that I have done importing for and worked fine
It only seems to import the last record on the CSV
Any suggestions?
It's hard to say based on the provided information what the reason is. Would it be possible for you to attach some screenshots of the import configuration for the object type and it's attribute?
Is it possible that the identifier is not unique, ie that all objects have the same value for the identifier, and therefor is treated as one object to be imported?
What IQL have you set for the object type, is it possible that it filters out all but one of the objects to be created?
Cheers!
Alexander
