I would lile to create custom release notes that only render issues with a lable = ReleaseNotes. I have been able to filter out sub tasks and other things but can't seem to figure out the syntax to only include issues with a specific label. Any help would be appreciated.
#set ($labels = $issue.getLabels()) You will then obtain an array of all labels, for this issue, in which case you could do a velocity loop to loop through them and get the labels you want. http://stackoverflow.com/questions/6328868/java-velocity-foreach-loop
Unfortunately I have not tested this yet though, perhaps you could try this and share your findings here.
Also, here is a useful link for some syntax information: https://developer.atlassian.com/display/JIRADEV/Creating+a+Custom+Release+Notes+Template+Containing+Release+Comments#CreatingaCustomReleaseNotesTemplateContainingReleaseComments-Step4:FilteringReleaseNotes
deleted
