×Well here is the scenario:
There are two boards in project lets say X1 and X2. X1 board is based on label X1 and X2 board is based on label X2.
I created a sprint S1 in board X1 and assign some X1 issues. Then as soon as i assign some X2 issues to the S1 sprint, it appears in the backlog of X2 board.
Now i started the sprint and it appears in Active sprints of both board. Let say there are 2 issues in X1 board of sprint S1 and 2 issues of X2 board of sprint S1.
When i click complete the sprint from X1 then it shows all the issues in the sprint i.e, issues from both the boards. I choose to move it to next sprint S2 and click complete.
Now the situation is issues in X1 moved to S2 sprint perfectly but issues in X2 moved to backlog of X2 board.
What could be the reason? Please help us on that.
Hello !
May it be a right issue? Do you have the manage sprint permission in both projects?
Hello Thomas,
As i said both boards are in same project. They are differentiated based on a filter. Please read the scenario one more time.
Regards
Bhakti Prasad Panda
Same issue here for one of my projects. Have you open a ticket with Atlassian yet?
I haven't yet. Until unless its been recommended from any community leader/ Atlassian team member, i can't create this directly. I asked this question here because it might help others to get to know about the same, Lets see.
I am seeing the same issue now, has anyone found a cause or resolution?
I'm having a similar issue, it shows in the History being added to the next sprint, then being removed. Are you also seeing that in your X2 issue history? I also am not able to move that ticket back into a sprint from the backlog, it's basically stuck in the backlog, which is a real problem for us.
@lukasz luniewski as far as I can see there is no voting mechanism for the issue, just for the answers. I don't see a linked Jira ticket
fyi. We have an add-on installed called BigPicture. The application engineers from BigPicture told me today that our issue is likely related to a bug with their application. They are planning to release a fix tomorrow, 9/17/2019. If you also have the BigPicture add-on, maybe this will fix the issues you're seeing as well.
