Incorrect use of atlassian-spring-scanner-runtime
Jackson Farnsworth
December 19, 2017
So I'm learning to make Service Desk Addons via this tutorial, and I'm getting the following error once I get to step 4.3:
org.springframework.beans.factory.BeanDefinitionStoreException: Unexpected exception parsing XML document from URL [bundle://261.0:0/META-INF/spring/spring.xml]; nested exception is java.lang.IllegalStateException: Incorrect use of atlassian-spring-scanner-runtime: atlassian-spring-scanner-runtime classes are embedded inside the target plugin 'com.atlassian.plugins.tutorial.servicedesk.servicedesk-automation-extension'; embedding scanner-runtime is not supported since scanner version 2.0. Use 'mvn dependency:tree' and ensure the atlassian-spring-scanner-annotation dependency in your plugin has <scope>provided</scope>, not 'runtime' or 'compile', and you have NO dependency on atlassian-spring-scanner-runtime.
I've gone back and restarted this tutorial from the start a few times and continue to get this error. I'm not sure what I need to remove from my pom.xml file to get this working. My pom file is in the comments due to size restriction in the description.
 Thank you in advance for any help you can provide.
PS: I've tried atlas-clean, no dice.
Jackson Farnsworth
December 19, 2017
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.atlassian.plugins.tutorial.servicedesk</groupId>
<artifactId>servicedesk-automation-extension</artifactId>
<version>1.0.0-SNAPSHOT</version>
<organization>
<name>Org</name>
<url>http://www.organization.com</url>
</organization>
<name>servicedesk-automation-extension</name>
<description>Adds a new when, if and then rule component to JIRA Service Desk's automation feature.</description>
<packaging>atlassian-plugin</packaging>
<dependencies>
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.10</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<version>${atlassian.spring.scanner.version}</version>
<scope>compile</scope>
</dependency>
<dependency>
<artifactId>atlassian-spring-scanner-runtime</artifactId>
<scope>runtime</scope>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
<version>${plugin.testrunner.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>jsr311-api</artifactId>
<version>1.1.1</version>
</dependency>
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>2.2.2-atlassian-1</version>
</dependency>
<!-- User Added Dependency -->
<dependency>
</dependency>
<dependency>
<groupId>com.atlassian.servicedesk.plugins.automation</groupId>
<artifactId>servicedesk-automation-api</artifactId>
<version>${servicedesk.automation.version}</version>
</dependency>
<dependency>
<artifactId>servicedesk-automation-spi</artifactId>
</dependency>
<dependency>
<groupId>org.springframework</groupId>
<artifactId>spring-context</artifactId>
<version>${springframework.version}</version>
</dependency>
<dependency>
<groupId>com.atlassian.pocketknife</groupId>
<artifactId>atlassian-pocketknife-api-commons-jira</artifactId>
<version>${pocketknife.api.commons.version}</version>
</dependency>
</dependencies>
<build>
<plugins>
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>maven-jira-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<products>
<product>
<id>jira</id>
<instanceId>jira</instanceId>
<applications>
<application>
<applicationKey>jira-software</applicationKey>
<version>${jira.software.application.version}</version>
</application>
<application>
<applicationKey>jira-servicedesk</applicationKey>
<version>${jira.servicedesk.application.version}</version>
</application>
</applications>
</product>
</products>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
<enableQuickReload>true</enableQuickReload>
<enableFastdev>false</enableFastdev>
<instructions>
<Atlassian-Plugin-Key>
</Atlassian-Plugin-Key>
<Bundle-SymbolicName>
</Bundle-SymbolicName>
<Spring-Context>*</Spring-Context>
<Export-Package>
</Export-Package>
<Import-Package>
com.atlassian.servicedesk.plugins.automation.api.*,
com.atlassian.servicedesk.plugins.automation.spi.*,
</Import-Package>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
<executions>
<execution>
<goals>
<goal>atlassian-spring-scanner</goal>
</goals>
<phase>process-classes</phase>
</execution>
</executions>
<configuration>
<verbose>true</verbose>
</configuration>
</plugin>
</plugins>
</build>
<properties>
<jira.version>7.5.0</jira.version>
<amps.version>6.3.6</amps.version>
<!-- User added properties -->
<atlassian.spring.scanner.version>2.0.1</atlassian.spring.scanner.version>
<servicedesk.automation.version>2.2.7</servicedesk.automation.version>
<springframework.version>4.1.7.RELEASE</springframework.version>
<pocketknife.api.commons.version>0.21.1</pocketknife.api.commons.version>
<jira.software.application.version>7.5.0</jira.software.application.version>
<jira.servicedesk.application.version>3.6.0</jira.servicedesk.application.version>
<plugin.testrunner.version>1.2.3</plugin.testrunner.version>
<!-- This key is used to keep the consistency between the key in atlassian-plugin.xml and the key to generate bundle. -->
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<!-- TestKit version 6.x for JIRA 6.x -->
<testkit.version>6.3.11</testkit.version>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
</properties>
</project>
Jackson Farnsworth
December 19, 2017
Found I just needed to run it in a different environment and it worked.
neetubhatt September 20, 2018
HI , can you please provide me the exact pom file that you are using after updating scanner version to 2.0 and the plugin-context file .After making changes iam still getting same error that you have mentioned .
Jackson Farnsworth
December 19, 2017 edited
Jackson Farnsworth
