Hi All
A network issue means that queries are timing out. How can I increase the time out? Am I correct in thinking that
mondrian.rolap.queryTimeout needs upping?
If so how/where do I do this?
Nick
PS: Yes I know the real solution is to sort the network issue;-) but I need an immediate fix.
If you are referring to JIRA's JQL, you can increase the User Session Timeout at https://confluence.atlassian.com/display/JIRA/Changing+the+default+session+timeout
You just need to be sure that you don't have a reverse proxy in front of JIRA with a lower timeout. ;)
