Is it possible to inherit from one field to another?
We have two use-cases:
- We need to inherit the current assignee as Reporter to the new subtasks
- we need to inherit from "custom-field 1" into "custom-field 2"
Hi @thomas ,
Could you describe your use case a bit more? From what I understand, you are looking to map specific fields from parent issues to different fields on child issues; is that correct? When do you need to do this? On a workflow transition? Or not necessarily? Does your instance have any apps already installed?
sure.
We have two different problems to solve:
Hi Laura,
We are modelling some business processes and some tasks need to be confirmed. In this scope we are using pre-defined create multiple subtask templates. There we need a way to map fields.
is there a way to map fields to another one?
Thomas
I don't think you will be able to do this out of the box with Jira, but there are some apps that might help.
The app Elements Copy & Sync (I work for the vendor behind the app) could help you because you can create field mappings for the issues you create using the app, and you could use Velocity variables to make the current assignee the reporter of the issue you create.
This tutorial is not an exact match with your use case, but it can give you an idea of how you could use the app: employee onboarding multiple subtask tutorial
