Inherit and Sync linked issue
Ash
May 30, 2017
Is there any addon or best way to inherit custom fileds values to linked issues and make the linked issues in sync with parent issues?
Ashish.
somethingblue
June 9, 2017
Hi Ashish,
I would take a look at the Communities post When you create a sub-task can you automatically inherit certain fields from the parent for the way others have resolved this issue in their instances:
Here is the advice from one user:
"In the create issue transition you can set the "Set Field Value from Parent" option in the post-functions. You can either do this in the default workflow you are using for the project, or make a separate workflow for sub-tasks. When only using this post-function, changing the value of the field in either the parent or sub-task will have no influence of the others value."
In addition you can also try Automation for JIRA.
Branden
Ash
June 12, 2017
Thank you Brande for you reply,
I'm testing this addon too Create and Link
Register now
